Results 1 to 1 of 1
Thread: Copy Layer Properties - Alter Properties
    2005-12
    90
    Default Copy Layer Properties - Alter Properties
    Here is the problem. I have queried in a drawing using alter properties to prefix the layers from that drawing with some object data ( The object data is the original drawing name.) The new layers created do not inherit the original layer properties from the source drawing.
    I am trying to envision how laytrans might work.
    How do you mass copy and rename layers with their layer properties intact?
    Thank you for any ideas,
    TC
    The solution I found was to query the object data to a new drawing and use 'RENAME' on each new drawing (rename * "dwgname *"). I do not plan on doing this again for a long time so it's good enough.
  1. Copy Layer Properties
    By mary.hammond in forum AutoCAD General
    Last Post: 2009-06-01, 06:22 AM
  2. One to Many SQL using Alter Properties
    By trconnet in forum AutoCAD Map 3D - General
    Last Post: 2006-05-11, 07:08 PM
  3. Create mtext (with alter properties)
    By gis.68227 in forum AutoCAD Map 3D - General
    Last Post: 2005-04-14, 03:37 PM
  4. alter properties querying images
    By dwilson.70674 in forum AutoCAD Map 3D - General
    Last Post: 2005-03-28, 07:51 PM
  5. Alter Properties - object data
    By gis.68227 in forum AutoCAD Map 3D - Wish List
    Last Post: 2005-02-04, 05:04 PM
