Results 1 to 7 of 7
Thread: wipeouts & curves
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Default wipeouts & curves
    is there anyway to get a wipeout to play nice with a curved line, or even another solution? right now the dialog states that it requires a closed polyline made only of line segments - meaning no curves.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: wipeouts & curves
    Nope. I experimented with this a while back to see if we could use them for detail bubbles. We had to make very short segments along the curve to to simulate a circle. It worked. Just took patience and the nearest osnap on...
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2005-03
    Derby, UK
    194
    Can you not draw a polyline and containing arcs and convert it into a mask block instead?
    Just a thought not really tried it out.
    Cheers,
    2006-04
    1,129
    Quote Originally Posted by gdaniels
    Cheers,
    hm. never tried. not even sure i know how. ill look into that later. thanks
    2006-04
    1,129
    Quote Originally Posted by gdaniels View Post
    Cheers,
    mask blocks only mask out aec objects which im sure has some great applications, but at the moment i am dealing with linework. they are a lot easier to work with than wipeouts from the little bit of experimenting ive done.
    2006-04
    1,129
    i did discover today while tinkering with this that an AEC Polygon set to masking functions just like a wipeout and the segments can be curved. this is the polygon that makes the AEC Cut Line work the way it does. might be a better way to make masking features than wipeouts.
    2007-12
    2
    We've been making multiple wipeouts, and the solution we found is to use a polygon set to many (50 to 100) for an arc. It comes in as one piece, can be trimmed, and works great for a wipeout.
  1. Wipeouts
    By kschultz in forum AutoCAD General
    Last Post: 2009-09-03, 04:53 PM
  2. Wipeouts
    By matt_grr in forum Revit Structure - Wish List
    Last Post: 2008-04-18, 03:42 PM
  3. Getting rid of wipeouts??
    By mcompanion in forum AutoCAD General
    Last Post: 2007-09-24, 12:40 PM
