Thread: Reassociate label fields
    2007-02
    61
    Default Reassociate label fields
    Hi All:
    I had removed a sheet from the sheet set and then reassociated it. Now the fields of my labels read as # signs and will not update if renamed. How can I resolve this issue without having to ...Egads!...recreate the sheet?
    Thanks
    Micheline
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Reassociate label fields
    you're not gonna like this. you have to find the ssm field's reference (for the view, i'm assuming) from within the ssm. depending on the project size, can be a pain to say the least. they are not organized per sheet....
    S&D DB Sharing Forum
  1. Replies: 1
    Last Post: 2013-07-16, 06:33 AM
  2. reassociate work plane?
    By RevitFairy in forum Revit Architecture - Families
    Last Post: 2010-04-12, 03:55 PM
  3. Multilined Fields - Label Blocks and Sheet Name
    By mazmier in forum AutoCAD Fields
    Last Post: 2008-11-03, 03:26 AM
  4. Fields in Label Styles
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2008-05-01, 09:50 PM
  5. Fields in Label Styles
    Last Post: 2007-09-17, 03:22 PM
