Whera can I find reliable hatch patterns, there are some on the rugi web library but most of them are invalid format when i try to import them from revit 6.1
thanks
thanks
Many of them are still in Autocad pat file form and then will prevent them being used as model fill patterns, I think. If you open the revit.pat file that is found in the program or data folder of your Revit installation it shows the appropriate syntax to make them work. You will have to spend a few minutes tinkering with the file but that's all it should take.
