Thread: OTRACK stop working in 3d
    2
    0 Did you find this post helpful? Yes
    Unhappy OTRACK stop working in 3d
    OTRACK works fine in 2d, stooped working in 3d. 3dpoly does not follow other lines directions. Extend it's stop working properly too.
    After snapping to endpoint, it shows that it is extending, but extensions are happening in X & Y coordinates.
    Anybody had this problem???
    Spend 2 days finding a solution, can not find anything.
    2008-10
    Sacramento, CA
    3
    Default Re: OTRACK stop working in 3d
    The newer versions require you to rotate the ucs when switching to a 3D view because it will only allow drawing on the x,y plane. When you switch to the left side view, for example, you will have to change the world ucs to left side. Hope this works for you.
  1. Extension, OTRACK, TT not working
    By melanie.santer in forum AutoCAD General
    Last Post: 2013-12-27, 09:25 PM
  2. Fields in tables stop working
    By cwjean76 in forum AutoCAD Tables
    Last Post: 2008-01-22, 04:51 PM
  3. Dynamic Blocks stop working
    By dduggins in forum AutoCAD General
    Last Post: 2007-10-10, 02:19 AM
  4. OTRACK stop working in 3d (in AutoCAD 2008)
    By rvitkauskas in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-08-14, 05:26 PM
  5. Commands stop working
    By ccowgill in forum AutoCAD General
    Last Post: 2006-03-23, 01:09 PM
