Results 1 to 7 of 7
Thread: preventing ungrouping
    2004-11
    16
    Default preventing ungrouping
    Is there anyway to prevent some one from ungrouping a group. we are working on a hotel with 5 floors guestrooms and someone our team ungrouped the the commons wall group which included the doors, corridor,demising walls and ceilings. I tried the pin command but it does prevent or warn a person that they are ungrouping a group.
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: preventing ungrouping
    Perhaps turning the Groups into separate .rvt files and linking them would be an alternative,
    especially if you have certain "core elements" that remain independent and need to be kept
    strictly segregated from other main model elements.
    Just a thought.
    Cheers....
    I could stop if I wanted to tonyisenhoff's Avatar
    Milwaukee, Wisconsin
    424
    Default Re: preventing ungrouping
    We had a similar situation... It was bad, bad, bad...
    Don't think you can do what you're asking - at least not directly...
    Not sure I would do this, but how about changing the group to a link (new feature in RAC 200? Just a thought. Eventually you could bind the link (turn it back into a group).
    I think your team needs some education...
    2003-04
    Chino, CA
    4,756
    You could put the group on a workset, and check it out under an "admin" user name and don't reliquish it.
    2004-05
    St. Louis, Missouri
    3,135
    Scott,
    Very crafty.........
    2004-11
    16
    Scott:
    Will I have to check the "admin" workset everytime I opening the drawings?
    2003-04
    Chino, CA
    4,756
    No, you can open your local file and the Groups in the "special" workset will still be displayed, but they will be checked out by Admin and wont be editable. You will have to start Revit using Admin as a user name in order to make changes to these groups, or to relinquish them so others will be able to access them.
  1. Preventing users from unloading links
    By JohnCAVogt in forum Revit Architecture - General
    Last Post: 2012-04-07, 10:16 AM
  2. 2011: Ungrouping objects
    By mike.may85957964 in forum AutoCAD General
    Last Post: 2011-05-27, 11:35 AM
  3. Quick Grouping / UnGrouping in AutoCAD 2006
    By blaine.67000 in forum AutoCAD CUI Menus
    Last Post: 2006-01-18, 01:33 PM
  4. Error message preventing any other action
    By J. Grouchy in forum Revit Architecture - General
    Last Post: 2005-05-31, 07:01 PM
  5. Preventing unauthorized prints
    By dlanguell in forum AutoCAD General
    Last Post: 2005-05-03, 04:18 PM
