Thread: masking region in 2d family
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,535
    Default masking region in 2d family
    We were trying to modify the return diffuser family so that it masks the ceiling that it is mounted in. The family is a series of model lines drawn on the face of the ceiling.
    I can create a masking region, but if I set it to the same plane as the ceiling, it doesn't mask the ceiling. If I set it to a workplane below the ceiling, it masks the ceiling, but it also masks the lines of the family that I want to see.
    It seems that the problem is that a masking region will not mask a surface pattern if it is drawn in the same plane as the surface. I would like it better if masking regions would draw with some type of display order to show the lines from the family that are draw in the same plane, but hide the model elements in the same plane.
    Thoughts? Is this the case or am I missing something?
    Steve
    2001-12
    1,714
    Default Re: masking region in 2d family
    Quote Originally Posted by sfaust
    If you draw your masking region and model lines on a plane 1/4" or so down from the ceiling, you will get what you are looking for. And if you set the model lines to not show in elevation at all, then you want get the fat lines at the diffuser in section and interior elevation. Kludgy, but it works. And display order sure would be nice.
    Gordon
  1. 2013: masking region in symbol family
    By mcheckis366322 in forum Revit Architecture - General
    Last Post: 2013-03-29, 07:40 PM
  2. Family and Masking Region
    By ronen.182152 in forum Revit Architecture - General
    Last Post: 2011-11-01, 02:05 PM
  3. Family Masking Region
    By antman in forum Revit Architecture - General
    Last Post: 2011-10-14, 06:32 PM
  4. Masking Region in generic family
    By WYSIWYG-BIM in forum Revit Architecture - Families
    Last Post: 2009-08-11, 03:44 PM
  5. Masking region in titleblock family
    By dbaldacchino in forum Revit Architecture - Families
    Last Post: 2007-05-11, 11:13 PM
