Thread: Un-Install old versions of AutoCAD
    I could stop if I wanted to rhayes.99001's Avatar
    2005-11
    New Jersey
    349
    Default Un-Install old versions of AutoCAD
    I just installed AutoCAD Architecture on a PC that still has ADT 3.3 on it.
    How can I un-install the ADT 3.3.????
    Using the Windows Add/Delete option does not work, the file does not show up
    in the program listing.???
    Certified BIM Addict Brian Myers's Avatar
    2003-02
    Working in Cyberspace
    1,682
    Default Re: Un-Install old versions of AutoCAD
    All you need to do is put your original CD in the drive and choose to install/uninstall.
    More can be found on this in this thread:
    http://discussion.autodesk.com/threa...hreadID=405554
    Brian Myers
    Sr Applications Engineer, Seiler Instrument | Autodesk Certified Instructor (ACI) Revit Architecture
    Creator of the Revit Users LinkedIn Community | Author of Revit Videos @ Lynda.com
  1. Is AutoCAD 2008 compatible with other versions?
    By drafting1 in forum AutoCAD General
    Last Post: 2007-05-09, 08:59 PM
  2. Replies: 2
    Last Post: 2007-03-05, 08:02 AM
  3. Enterprise CUI with different versions of AutoCAD?
    By jcapp in forum AutoCAD CUI Menus
    Last Post: 2006-11-02, 06:05 PM
  4. AutoCAD Drawing versions?
    By JasonSelf in forum CAD Management - General
    Last Post: 2006-04-18, 07:28 PM
  5. Compatibilities versions Autocad with Windows XP
    By James in forum AutoCAD General
    Last Post: 2005-03-01, 02:26 PM
