Thread: "Open Text Failed" error message???
    2007-01
    Dallas, TX
    57
    Question "Open Text Failed" error message???
    One of my drafters was doing a spell check and it came back with a "Open Text Failed" error message. Any ideas what might be causing this??
    Kelli
    2015-12
    Near Charlotte, NC (Clover, SC)
    112
    Default Re: "Open Text Failed" error message???
    Can you upload a picture of the error message or the actual message?
    Quote Originally Posted by KELLI
    Kelli
    2016-01
    Did you ever find out what caused this? I am having the same issue.
    Cairo - no, not Illinois
    5,069
    Do you have OpenText or some other DMS application installed?
    2012-11
    15
    I think I have your answer!
    I got the same error on a page of wall sections. Our wall section drawings with elevation tags and bearing text are in an x-ref. The actual sheet(s) with the sections has this X-Ref brought in and then all the notes for each section go on the sheet. If I do a spell check for the entire drawing it sees the text in the X-ref and gives the "Open Text Failed" message and if you hit OK it will pop up over an over for each piece of text in the xref. Once it passes those it works fine. If I do a spell check and select only the text in that sheet then it works fine with no error. I tried doing a spell check and selected only the X-Ref which has 11 pieces of text in it and the "Open Text Failed" message popped up 11 times and then said "Spelling Check Complete"
    Quote Originally Posted by KELLI View Post
    Kelli
  1. Replies: 4
    Last Post: 2022-05-31, 12:03 PM
  2. Erroneous "Cannot open central + local model" error message
    By Rustle in forum Revit Architecture - General
    Last Post: 2010-09-13, 04:54 PM
  3. Error Message: Failed to Open Document
    By mccurdyks in forum Revit Architecture - General
    Last Post: 2006-10-06, 12:24 PM
  4. Replies: 2
    Last Post: 2006-06-20, 05:12 PM
  5. Error "Failed to Save Document"
    By dgraue in forum Revit Architecture - General
    Last Post: 2005-11-17, 08:03 PM
