Results 1 to 6 of 6
Thread: Changing thickness of Property Line
    2005-11
    76
    Post Changing thickness of Property Line
    I know how to change, edit and create new lines [Lines Styles in the Settings menu], but how do I change the thickness of the Property line that is created with the Site tools?
    For now I found this workaround: Once I have created by the Property Line I exchange it with a Line Type I've created. This works fine, and I doubt there is no better way.
    Thanks for your help
    Axel
    2001-12
    1,714
    Default Re: Changing thickness of Property Line
    Quote Originally Posted by abink
    Axel
    Go to Settings/Object Styles, then scroll down and open the Site Category. There will be a Property Lines sub category, with a Projection Line Weight that you can change. I think that will get you what you are looking for.
    Best,
    Gordon
    2005-11
    76
    Smile Re: Changing thickness of Property Line
    Thanks a lot, Gordon,
    that's exactly what I was looking for!
    2012-01
    59
    forgive me if im being a newbie but i cannot find 'settings' anywhere in revit 2012..
    2012-01
    59
    i cannot seem to find 'settings' anywhere in revit 2012..
    2012-01
    59
    I found it under the manage tab
  1. Changing Wall thickness
    By karalyn.patrick in forum Revit Architecture - General
    Last Post: 2010-08-16, 02:06 AM
  2. Site Property Line - Strange Effect on Model Line Family
    By Batman in forum Revit Architecture - General
    Last Post: 2007-02-08, 04:31 AM
  3. Changing Line Thickness
    By .chad in forum ACA General
    Last Post: 2006-05-03, 06:00 PM
  4. Line thickness
    By methost in forum AutoCAD General
    Last Post: 2005-10-03, 02:28 PM
