Thread: Revit Links Display Discrepancies
    2006-07
    4
    Unhappy Revit Links Display Discrepancies
    We have a site with 5 buildings on it. Previously we had all the buildings in one project but recently we separated the project into different files all linked into one site file. We are encountering a problem in how the largest building displays within the host file. Certain elements (floors and groups of floors and railing families) do not display. Some of the same elements display but other instances do not. I have attached two images one of the Linked file with everything displaying and one of the host file with the missing elements. I have purged out all the projects and reduced them as much as possible.
    Some of the elements, but not all, that display incorrectly are in different groups in the linked file. Could this be part of the problem? It's not a work set issue as I have tried putting the elements on different work sets in the linked file but they still do not display? The linked building file is rather large with about 6 work sets.
    The display problem happens in all views (plan, elevation and 3-d). However if in the Host file I tell the linked file to display per a linked view the elements appear as they do in the original file. But as you cannot link 3-d views or elevations we need to solve the problem so we can take 3-d views of the site and have everything display properly.
    I have also tried linking the building file that is not displaying correctly into a new revit file and the same elements do not display correctly?
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Revit Links Display Discrepancies
    Are they on a workset you didn't load? are they masses? Check if masses are turned on in VV.
    Scott D. Brown, AIA
    BECK
    2006-07
    4
    Thanks for the suggestion, but the elements that do not show are on the same wokset as other elements that do show so I do not think that is the problem. Furthermore when I linked the file I loaded all worksets. Also I do no think masses are an issue becuase the elements that do not show are floors, railings and stairs.
    It may have something to do with groups? The linked file has many complicated model groups within it. It just baffling.
    2005-07
    Somewhere in the BIM world
    3,792
    Could it be a display issue of your video card ?
    How is it setup, OpenGL and Overlay Planes ?
  1. 2013: discrepancies with plotting pdf
    By matthew.221135 in forum AutoCAD General
    Last Post: 2013-05-24, 02:33 AM
  2. Rebar Summary Table - Discrepancies
    By swmarais in forum AutoCAD Structural Detailing
    Last Post: 2012-11-21, 06:10 AM
  3. Discrepancies using Point Clouds in Revit Architecture
    By dfluegeman in forum Revit Architecture - General
    Last Post: 2012-04-13, 02:17 PM
  4. Revit links Display Settings in Ceiling plans
    By dbaldacchino in forum Revit Architecture - General
    Last Post: 2006-07-24, 09:21 PM
  5. Toggling Links Display
    By raddis in forum Revit Architecture - General
    Last Post: 2006-03-30, 12:45 AM
