Thread: Text will not print or view in paperspace
    2005-08
    378
    Cool Text will not print or view in paperspace
    Guys,
    I am making a drawing and have noticed that the file will not show the leaders or text. I have checked the layers are set to print etc I can not see a reason why they will not print.
    I have purged, audited and run a recovery on the file though without luck. Can anyone see anything obvious or is this file just corrupted ? I am just curious if there is something for me to learn or a dud file.
    Stephen
    2007-03
    Someplace
    46
    Default Re: Text will not print or view in paperspace
    In paperspace click the viewport - change the scale to something else (1:50) then change it back to 1:100, they should show after it regens.
    2003-12
    20
    The "current view" is frozen/off for two layers with the leaders.
    Open viewport, click layers, turn on the two layers that are frozen/off. You'll see to lil blue-ish suns, click em to turn em on. it's the sun with the lil box in the lower right corner.
  1. How Do I Plot PaperSpace View w/ NO Offset?
    By chillme1 in forum AutoCAD Plotting
    Last Post: 2009-01-14, 11:19 AM
  2. Paperspace Text Plots slightly thinner than Modelspace Text
    By jeattende in forum AutoCAD Plotting
    Last Post: 2005-10-01, 07:07 PM
  3. Paperspace text heights
    By todd.mackay in forum AutoCAD General
    Last Post: 2005-07-07, 12:21 PM
  4. Editing Text in Paperspace
    By BWG in forum AutoCAD General
    Last Post: 2005-06-24, 02:15 PM
  5. PaperSpace view Issue
    By thomas.stright in forum AutoCAD General
    Last Post: 2004-12-17, 10:14 AM
