Thread: I create a Corridor Surface but no Corridor Surface appears?
    2006-10
    24
    Unhappy I create a Corridor Surface but no Corridor Surface appears?
    Hi all,
    Need a little help please. I created a Corridor and wanted to detach the surface so I could paste it into another and get a quantity take off. The detached surface appeared in tool space but could not be exported to xml nor did it physically show up in the drawing? And when I open the properties box to statistics it’s grey and blank. When I expot the surface it gives me a 1k file with nothing in it. Any ideas floating around out there?
    I could stop if I wanted to dfarris75's Avatar
    2004-12
    where ever i'm at
    252
    Default Re: I create a Corridor Surface but no Corridor Surface appears?
    You might upload the file for a peek.
    2006-10
    24
    Lightbulb Re: I create a Corridor Surface but no Corridor Surface appears?
    I figured it out but thanks anyway, just for others who might be interested and are under educated like me here’s what happened.
    After creating a surface using: ( Corridor Properties dialog box / surfaces )
    You have to click the Add data
    Data type: Links
    Specify code: Top
    Then the surface will be created. If anyone lese has a much for technical way of putting it please add more to this post so as to help other newbie’s like me.
    Thanks you guys are all great!
    Civil Engineering Moderator MHultgren's Avatar
    Clyde, NC - USA
    1,381
    You can also have C3D draw your feature lines (Curb, Gutter, Sidewalk, EOP,etc...) and add them as breaklines in your plan view as well.
    Sorry I didn't get in here quick enough to answer your question.
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
  1. create a corridor without a surface?
    By Maverick91 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2011-07-13, 11:21 PM
  2. Corridor & Prop Surface
    By kolk in forum AutoCAD Civil 3D - Corridors
    Last Post: 2011-04-26, 03:08 AM
  3. Corridor surface
    By tim_newsome in forum AutoCAD Civil 3D - Corridors
    Last Post: 2010-08-05, 04:42 PM
  4. Corridor Top Surface Question
    By EngME in forum AutoCAD Civil 3D - Corridors
    Last Post: 2009-12-22, 03:02 PM
  5. Corridor to Surface
    By jsnyder.105561 in forum AutoCAD Civil 3D - General
    Last Post: 2006-02-13, 04:37 PM
