First Time Forum Posting so bear with me. Thank you.
Ok loaded up AutoCAD Civil 3D 2008. Setting up my CUI file. Wanted to make a new CUI file so not to corrupt or change the existing CUI files that came preloaded. I took a stab at it and it did not work. Figured I messed up something in the process so I unistalled and reinstalled. So I am starting all new. Is there a step by step process that I should do in creating my own CUI file. When I attempted the first time, one of the problem that came up was the Partial CUI Files did not load. Another problem I had was it would not keep the change that I did make. Like adding the Draw pull down menu. So any help would be greatly appreciated.
JLizard1
