Thread: UCS and Tables
    2007-08
    Brisbane, Australia
    42
    Post UCS and Tables
    Can I change the UCS and have (alignment) tables use the new orgin for Easting and Northings?
    Is there another way?
    MVI
    Civil Engineering Moderator MHultgren's Avatar
    Clyde, NC - USA
    1,383
    Default Re: UCS and Tables
    If you right click on your Drawing Name in the Settings Tab of the prospector window you can change the coordinate system, by may I ask why? Doing the above will also change all of your point coordinates as well.
    If you are looking for a way to change the N & E to follow your alignment, you may want to look at creating an expression for your labels.
    I have always made it a habit to NOT change the UCS when working on Civil projects. If I want to change the way a viewport is displayed (oreintation of North) , I will use DVIEW with the Twist option.
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
    2007-08
    Brisbane, Australia
    42
    Thumbs up Re: UCS and Tables
    I agree that no one should ever do this for a job, but we are still in our development phase with C3D and we were working off an incorrect survey file for a example/trial design.
    Thanks for your help.
  1. Tables, Tables...........
    By TEAMSTAC in forum VBA/COM Interop
    Last Post: 2007-10-02, 05:01 PM
  2. Tables
    By somared in forum AutoCAD Tables
    Last Post: 2007-09-19, 01:25 PM
  3. CSV Tables
    By mabrey in forum Revit MEP - Families
    Last Post: 2007-08-25, 05:02 AM
  4. Microstation plot tables to AutoCAD plot tables
    By khager.72055 in forum AutoCAD Plotting
    Last Post: 2006-06-21, 12:34 PM
