Results 1 to 9 of 9
Thread: Curved Elevations???
    I could stop if I wanted to Matt Brennan's Avatar
    2005-02
    Vancouver, B.C. Canada
    281
    Default Curved Elevations???
    Hi Everyone,
    I was wondering if anyone knew a trick on how to do a curved sections/elevation? We have a building has a huge amount of curtain wall that is curved and we wondering if we could do a dead on elevation of each panel of glass for say. I have looked through the forums and didn’t find anything but maybe I am searching for the wrong thing. Any help would be appreciated.
    Thanks in advance,
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,564
    Default Re: Curved Elevations???
    Sorry to say, but there is no way to create a curved elevation at the moment.
    It's unlikely to happen anytime in the near future, either.
    The Revit philosophy is to give you real-world views & a Curved elevation is "cheating". What do you do with the back side of the wall? If it's not perpendicular to the curve, which part of it do you draw?
    The only thing I can think of that would approximate what you want is to place a bunch of elevations perpendicular to each Curtain Wall panel (because, you really want it segmented, not curved, right?) and then composite the separate elevations on a sheet. They should snap into place vertically , but you'll have to eyeball them horizontally.
    Go back to AutoCAD? I'd rather lose my right arm!
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,510
    I am pretty sure you have a single curtain wall segmented, so the elevation mark won't react to each segment like it does with a linear wall....
    I haven't done this in a long while, but am pretty sure that the elevation will react to reference planes.
    If they do, place reference planes on each segment, you can align, or pick the edge of the mullion for each segment...then create an elevation for each segment....line up all these elevation next to each other, dimension and note at will...
    it is a process to go through, not quick and easy, and I would question the real need for the contractor to get that information as true elevation, nonetheless....the process will be longer than usual, but not too extreme...hours not seconds or minutes...
    In case the need of a true elevation of a curved wall is something that you need to argue, the only thing that the elevation shows are heights, not planar dimensions, so all you need is a top and bottom of each horizontal member on your elevation, you don't need the full/true elevation to do that.
    Take care,
    Quote Originally Posted by independentdrafting View Post
    Hi Everyone,
    Thanks in advance,
    2005-02
    281
    Well thanks guys for all the help. I knew there wouldnt be a simple answer for this in which it was also explained to the client as well. But thank you again for your insight towards this puzzling question.
    Take care,
    2015-12
    Vancouver, BC Canada
    3,744
    Matthew,
    sounds like a job for your glazing contractor
    If you really need to do this I believe there are a number of AutoCAD third party apps that will do this. They were created for the sheeet metal industry I think. Not sure if they can be applied to curtain systems but it might be worth investigating.
    So, an export to ACAD and then a quick run through so you can re-import into your Revit file as a DWG.
    Active Member balazs.trojak's Avatar
    2008-02
    Leeds, UK
    95
    I was thinking maybe a perspective view would do this trick. I placed the camera at the centre of the curve but the results are not encouraging.
    2005-12
    566
    While I think it would be possible to write software for producing an unfolded elevation, I think the best thing to do in the case of elevating a curved curtainwall is to either show each planar panel separately (as discussed) or what we did on one occasion: Draft using drafting lines! We produced a single-line diagram to illustrate the structure of the curtainwall, without showing thickness of mullion or anything else.
    I could stop if I wanted to mthurnauer's Avatar
    2001-11
    Cincinnati, formerly Chicago
    400
    My current project which is under construction has long runs of compound curves of curtainwall and I documented it by having curtainwall plans which deal with all of the horizontal dimensions and the the vertical dimensions are done in section and true elevation views.
    2006-01
    4,516
    Quote Originally Posted by Mike Sealander View Post
    ...Draft using drafting lines! We produced a single-line diagram to illustrate the structure of the curtainwall, without showing thickness of mullion or anything else.
    I wouldnt want to be monitoring the budget on a project that did that, if the entire radius of that wall has to change at some point. It certainly wont be BIM like, and it might just detroy your budget.
  1. Curved Elevations
    By andrew.brahney10 in forum Revit Structure - General
    Last Post: 2009-04-19, 08:04 PM
  2. Curved elevations
    By andrew.brahney10 in forum Revit Architecture - General
    Last Post: 2009-04-18, 12:16 PM
  3. how to make curved window with curved arch trim in curved wall
    By lcollot in forum Revit Architecture - Families
    Last Post: 2008-01-21, 02:46 PM
  4. ADT2006: Flat elevations of curved walls possible?
    By joao_cota in forum ACA General
    Last Post: 2005-11-11, 11:16 AM
  5. Curved walls can't have their elevations modified?
    By J-G in forum Revit Architecture - General
    Last Post: 2004-11-12, 03:49 AM
