I getting a couple errors when exporting a sheet to a CAD format (.dwg). The sheet being exported is an elevation sheet with 4 elevations. The problem shows itself when I export the sheet. But, if I remove one of the larger views from the sheet, then it's exports fine.
  1. FIll pattern shifts
  2. Some lines are missing
Could it be a file size issue? I run into printing issues with what Revit determines a large amount of filled region. Raster Printing ususally fixes that.
Any suggestions?
