Problem: I’m trying to use the detail component manager but the dialogue box is not coming up; when I pick the command icon it simply displays _AecDtlCompManager in the command line. Is this an easy fix?
are the prompts showing up, or just that text and nothing else. if so look into filedia
Sounds like your detail component manager is showing in another display. did yu use to have 2 displays?
If you click ALT+F4 you then again can type another command, but you can´t escape it.
Try to set up you grficcard to show only 1 display.
