ford347
Use the join roof tool for the dormer problem. That will join the dormer roof to the face of the mainspan roof and get rid of the chunk of roof you are showing in your image.
As far as the split pitch, use a roof by extrusion. That will keep the roof as one and make this a smooth transition. Only problem is you don't have the convenience of a footprint roof with the pitch and wall association. But if you design isn't going to change much, then this should work fine. If you do stick with a footprint roof, just use the edit cut profile tool in sections and any detailing tools to help alleviate the visual problem.
Hope this helps.
Josh
