Thread: New to Revit API
    2005-11
    175
    Red face New to Revit API
    Hi
    i've been using Revit for a while, but am completely new to Revit API. i decided to look through the samples and the help available, but i have some problems. I hope someone can help me out!
    for eg: i edited the revit.ini file to include the code from the sample ' all views' . i added it just as below.
    [ExternalCommands]
    ECCount=2
    ECName1="Earth Connector"
    ECDescription1="Avatech Earth Connector for Revit 2008"
    ECClassName1="EarthConnector.Command"
    ECAssembly1="C:\Program Files\Avatech Solutions\Earth Connector Revit\EarthConnector2008.dll"
    [ExternalCommands]
    ECCount= 1
    ECName1= All Views
    ECClassName1= Revit.SDK.Samples.AllViews.CS.Command
    ECAssembly1= AllViews.dll
    ECDescription1= A new sheet will be generated according to the views selected by the user.
    One thing i noticed is there is no dll file in the folder all views. RAC opens up normally and does not show the all view command, but does show the erath connector command.
    Can someone help me with what i am doing wrong?
    thanks in advance!!
    Winn
    2003-11
    New Zealand
    1,116
    Default Re: New to Revit API
    Try this:
    [ExternalCommands]
    ECCount=2
    ECName2= All Views
    ECClassName2= Revit.SDK.Samples.AllViews.CS.Command
    ECAssembly2= AllViews.dll
    ECDescription2= A new sheet will be generated according to the views selected by the user.
    Note you still need to compile the AllViews sample and put the correct path to the dll in the ECAssembly2= [Path to dll]\AllViews.dll line above.
    HTH,
    Guy
    2005-11
    175
    Thanks Guy
    by compile, do you mean use VB.Net to compile the allviews sample? forgive my ignorance, but i'm really quite new to this!
    thanks again
    Winn
    2004-02
    Brookline, MA
    185
    Yes, none of the SDK samples are compiled - you'll have to compile them yourself.
    If you open the "SDKSamples10.0.sln" file, it's a Solution which contains project references for all the samples - this will let you compile them all at once.
    Best Regards,
    Matt
