Results 1 to 10 of 10
Thread: Opening multiple drawings from outside AutoCAD
    2006-08
    25
    Question Opening multiple drawings from outside AutoCAD
    Hope I can make this clear enough to understand:
    It seems several of our users are having an issue with opening multiple files outside of AutoCAD. What they are doing is highlighting multiple drawings either in Windows explorer or in our File management system (Adept) and when they hit open it will do 1 of two things. In Adept it will open 1 session of AutoCAD for EACH drawing highlighted (if a session of AutoCAD isn't running when the command is given). When they try to open multiple drawings from Windows explorer it will only open the last drawing selected.
    Is there a setting within AutoCAD 2008 that needs changed? They say they never had any problems with 2006 and that when they chose to open multiple drawings either way they would get one session of AutoCAD with all the drawings open.
    Thanks for any help you can give me!
    All AUGI, all the time Richard.Kent's Avatar
    2001-01
    Albuquerque, NM, USA
    621
    Default Re: Opening multiple drawings from outside AutoCAD
    From File Explorer > Tools > Folder Options > File Types > wait, wait some more > highlight DWG in list, > Advanced
    > highlight open > Edit... > (If open isn't there use New.. to create it.)
    Application used to perform action:
    "C:\Program Files\AutoCAD 2008\acad.exe" "%1"
    Use DDE
    checked
    DDE Message:
    [open("%1")]
    Application:
    AutoCAD.r17.DDE
    OK > OK > Close
    2006-08
    25
    It worked the second time, I had a delay when the IT guy came in to install a second monitor. Somehow the second time it worked. Thanks so much I really appreciate the help I have gotten from this forum!!
    2004-08
    Hartford, Michigan
    3,086
    you could also download service pack 1, they took care of the problem.
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    2002-07
    8
    Is this the same for Vista, any idea?
    2008-08
    I have the same problem listed here. On my computer, it would only open the last drawing selected, so I tried changing the advanced options, but they wouldn't stick. Then I tried changing the registry to open acad.exe instead of the launcher which allowed it to open all the drawings but in different sessions. I added ddeexec to the registry, but it still won't change. When I go back into the file type advanced options it is back to the way it was before.
    0,0,0 The Origin
    8,028
    Changing SDI to zero inside acad may help.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2003-05
    4
    Hurray it works,
    Thanks Richard.kent
    Pants
    2008-02
    2
    Wink Re: Opening multiple drawings from outside AutoCAD
    This worked for me!
    Thanks
    -Slimpickinz
    Quote Originally Posted by Richard.Kent View Post
    Use DDE
    checked
    DDE Message:
    [open("%1")]
    Application:
    AutoCAD.r17.DDE
    OK > OK > Close
    2008-02
    2
    Sometimes other applications take over the default for opening drawings.
    When this happens, apply the following in the initial screen:
    > Advanced (If advanced is not available, select “Restore”)
    then continue with the rest.
  1. Opening Multiple Drawings on Autocad Land Desktop 2009
    By ebhram in forum AutoCAD Land Desktop - General
    Last Post: 2009-06-09, 10:54 AM
  2. Opening multiple drawings in MEP 2008 sp1
    By bearden383 in forum AutoCAD General
    Last Post: 2008-04-16, 12:14 PM
  3. Opening Multiple Drawings
    By kryptonite_186 in forum AutoCAD General
    Last Post: 2008-03-04, 09:57 PM
  4. Opening Multiple Drawings
    By litchfieldl in forum AutoCAD Civil 3D - Land Desktop Companion - General
    Last Post: 2007-09-08, 12:50 AM
  5. AutoCAD LT 2006 - Opening multiple drawings within same session
    By lazer2go in forum AutoCAD LT - General
    Last Post: 2006-11-30, 09:00 PM
