Hello:
I'm having problems creating a generic annotation tag that contains a rotation parameter.
The tag in question will contain two items:
(1) A symbol which parametrically rotates.
(2) A label which does not rotate.
Based upon suggestions in other threads, I created an annotation symbol first, then loaded it into the annotation tag. I rotated the symbol, an applied an angular dimension to the symbol and assigned a rotation parameter to it.
Here's the problem: when I flex the family, the symbol's location will change whenever the rotation value exceeds 180 degrees. How can I stop this behavior?
I've attached the family. Any help/suggestions are welcome. Thank you!
