Thread: Funny topo in Exterior Elevations
    2005-03
    Seattle
    48
    Default Funny topo in Exterior Elevations
    I have done a graded region and the existing grade shows as blank in the view with Show Previous + New. When I change to "Show All" you can see the dashed exisitng grade. How can I get my entire elevation to show.
    I could stop if I wanted to Tobie's Avatar
    2004-06
    South Africa
    286
    Default Re: Funny topo in Exterior Elevations
    You need to do a pad around the exterior wall line. This will create a line where the building meets the site. When you change to shaded with edges, the extent of the site will be obvious
    2005-03
    Seattle
    48
    My "new" pad currently is drawn to the exterior face of the exterior wall. What do you mean "around the exterior wall line"?
    2004-06
    South Africa
    286
    Hi there.
    The pad just needs to be where you will see the site and wall line meet. The fact that you can not see a line on the elevations indicate that the pad is "in" the wall line somwhere. Just check position when editing the pad. Post file if you still have a problem.
    Cheers,
  1. 2014: Custom Labeling Exterior Elevations - Keynotes?
    By arcitek in forum Revit Architecture - General
    Last Post: 2014-10-28, 04:58 PM
  2. 2011: Exterior Elevations for Revit
    By jorgeo238926 in forum Revit - Tutorials
    Last Post: 2014-01-29, 06:12 PM
  3. Exterior Elevations
    By ty_demo15 in forum ACA General
    Last Post: 2007-11-27, 10:05 PM
  4. Colored Exterior Elevations
    By jbdesign in forum ACA General
    Last Post: 2006-09-24, 04:22 PM
  5. Elevations topo to Levels
    By mjl in forum Revit Architecture - General
    Last Post: 2004-07-05, 11:13 AM
