When starting autocad 2008 I get the following message:
"The A program name changed from a.exe to acad.exe. Some commands and add-on customization may not load correctly. Continue anyway?"
Any suggestions on how to fix?
Not quite sure. Are you using strictly AutoCAD 2008? Or are you using one of the vertical applications built on AutoCAD, such as Civil 3D?
Does you company have a custom script to execute AutoCAD?
Just looking for a bit more information which may help someone that may know the answer.
Looks like a Registry Cleaner issue. Take a look at this thread on the Autodesk Discussion Groups:
http://discussion.autodesk.com/threa...hreadID=499996
