Thread: ACA 2008 Project Details
    2007-02
    Alexandra, New Zealand
    237
    Default ACA 2008 Project Details
    HI All.
    Attached are two Pics.
    1. ProjectDetails.JPG shows The project details as entered in the project Navigator of ACA 2008 with default values set to some of the Nodes.
    2. A custom VB form that can read those values and also change those values to what has been set in the VB form. This changes the Project.APJ file.
    This all works fine, and our code that we have been working on that uses these project wide values is all working great. What we are however wanting to do is.
    1. If a project has been loaded that does not have these Nodes (ie Snow Zone) in the Project Details section of the *.APJ file, is it possible to add that by default, when the form is loaded? We have found no way of doing this.
    Any help would be apreciated.
    Regards
    Phillip Miller
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,776
    Default Re: ACA 2008 Project Details
    What have you not found a way to do? ...add an xml node? ...or the logic required to find out if it exists and add it if not found?
    C:> ED WORKING....
    2007-02
    237
    Hi Ed.
    We were having trouble with Adding Nodes, but we have it sorted now and it works sweet.
    Cheers
    Phillip
  1. Project Details
    By joelsyndergaard in forum Project Navigator
    Last Post: 2010-08-15, 02:05 PM
  2. Project Details Problem
    By dmayerTTP in forum ACA General
    Last Post: 2008-04-09, 06:16 PM
  3. Project Details
    By archdraught in forum ACA General
    Last Post: 2007-09-07, 12:37 AM
  4. Project Details Not Sticking
    By jbseltzer in forum ACA General
    Last Post: 2007-01-04, 03:40 PM
  5. Project details not editable
    By asandli in forum ACA General
    Last Post: 2005-07-22, 03:42 PM
