Results 1 to 10 of 10
Thread: Top of Footing Elevation
    2001-03
    Philadelphia
    8
    Default Top of Footing Elevation
    We should have the option of showing Top or Bottom of footing elevations not just bottom.
    100 Club jsr13's Avatar
    Virginia - USA
    134
    Default Re: Top of Footing Elevation
    Jon - I knew this would make a difference for you! Wait - are you only showing BOF? Ours works as TOF, so maybe this is already as selectable option.
    I've found that calling out "top of footing" or "bottom of footing" is a regional thing, so why not have it a selectable option? Especially for those firms that have work in a wide range of areas.
    2002-12
    2
    I agree, top of footing should be an option to add to a tag. As far as i can tell "elevation at bottom" is still the only option for a foundation tag.
    2006-09
    442
    I agree that you should have the option for both. Not just one. At the very least make the bottom of footing parameter a shared parameter, that you can access from with inside the family. This way you could set up a top of footing elevation parameter based on a formula.
    2005-08
    16
    I have to reply as I agree as well. This is a must have as we need to have the top of footing value available. Good wish!
    All AUGI, all the time kathy71046's Avatar
    2004-07
    Perth Australia
    736
    This would be really really really helpful, and save me a LOT of spot elevations.
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
    100 Club priitl22047477's Avatar
    2003-02
    Tallinn,Estonia
    193
    I'll second that.
    Active Member dlampley.41310's Avatar
    2002-11
    Kentucky
    72
    AGREE! The ability to add T.O.F. to my tags would save me LOADS of time.
    2005-08
    13
    Yes, Agree. Our office standard is to always callout TOF. We do alot of drilled pier jobs where BOF is at best a guess.
    2002-11
    Kentucky
    72
    I would think that TOF elevation would be a rather simple thing for the developers to provide. I would love to see them issue this in an update/patch/service pack.
  1. TOP OF FOOTING ELEVATION
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2017-04-17, 12:55 PM
  2. FOOTING TAG W/ FOOTING ELEVATION
    By dbumgarner in forum Revit Structure - General
    Last Post: 2012-07-20, 02:31 AM
  3. Bottom of footing elevation
    By Tom Weir in forum Revit Structure - General
    Last Post: 2008-09-18, 09:39 PM
  4. Bug: Bottom of Footing Elevation
    By Steve Mintz in forum Revit Structure - General
    Last Post: 2006-05-25, 07:36 PM
  5. footing in elevation hidden below grade
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2006-03-14, 04:24 PM
