Results 1 to 9 of 9
Thread: double click edit is gone
    2001-07
    312
    Default double click edit is gone
    Hello,
    I've lost the possibility to edit a block with the double click
    The variables
    dblclkedit=on
    pickfirst=1
    Which variable have I miss to edit a block (refedit) with a double click?
    NB I do can edit a text with a double click. The problem occur only with blocks.
    Thanks
    150700
    3,434
    Default Re: double click edit is gone
    Quote Originally Posted by clovis View Post
    Hello,
    The variables
    dblclkedit=on
    pickfirst=1
    Thanks
    check in your CUI, under dbl click actions, to see what action is assigned to blocks.
    2001-07
    312
    Hello,
    That's odd, I don't have those dbl click in my cui ?!?
    I have mechanical 2006
    Thanks
    150700
    3,434
    Hello,
    Thanks
    I believe that was a new feature in 07; let me see if I can find a copy of 06 to look at and see if I can figure it out
    2015-11
    Fairbanks, AK
    136
    Check under the command "options"; tab "User Preferences"; section "Windows Standard Behavior"; choice "Double Click Editing"
    I know the keyboard commands are set right, but sometimes they do not keep that box checked under that tab.
    2001-07
    312
    Hello,
    I can't see this option ?!?
    Here a pic
    Thanks
    2015-11
    Fairbanks, AK
    136
    Ok, well then my recollection to the availability of that choice in 2006 is incorrect. I am sorry about that. Autocad must have added it in the 2007 version. That is odd that variables are not working.
    Sorry I couldn't be of more help.
    Bill
    2001-07
    312
    Hello
    The problem was that mys::Startup wasn't append to the main one
    Thanks to all
    2007-05
    I have a similar problem that I cannot figure out. With ACAD 08 when i double click on an object. text, block, pline etc. it activates the correct command to edit it, however as of a week ago it does not automatically select the object and perform the appropriate command. For example double click on mtext. Mtext edit command activates and i have to reselect text and press enter to edit. It is as if pick first is off but it is not and it recently started doing this where it did not before. I am stumped and help would be much appreciated.
  1. double-click for text edit
    By Maverick91 in forum AutoCAD Customization
    Last Post: 2015-02-27, 06:52 PM
  2. Can't double click to edit text.
    By Darren Allen in forum AutoCAD General
    Last Post: 2013-11-23, 06:09 AM
  3. Double click edit
    By sandeep_koodal in forum AutoCAD LT - General
    Last Post: 2009-04-16, 06:21 AM
  4. Double-Click on Dimensions to Edit
    By Spenner in forum AutoCAD General
    Last Post: 2006-04-03, 09:19 PM
  5. Double Click to 'Edit'
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2004-10-27, 12:43 AM
