Results 1 to 7 of 7
Thread: extrude along a path
    100 Club tomcarver's Avatar
    2015-11
    Tucker, GA
    106
    Default extrude along a path
    Hi,
    Is it possible to extrude an object (closed pline?) along a closed rectangular path?
    thanks
    2005-06
    in the upper right corner
    3,508
    Thumbs up Re: extrude along a path
    Quote Originally Posted by tom.g View Post
    Hi,
    thanks
    Yup it is. I wasn't sure, so I tried it.
    I drew a rectangle, placed a circle on one corner, rotated the circle in the z axis so the center of the circle was on the line of the rectangle.
    Command "extrude" (select circle) "enter" "path" (select rectangle) "enter"
    2007-10
    4
    Default Re: extrude along a path
    Hi,
    I'm new on this site as well on this forum too. I'm learning about 3D's nowadays. I have some problems. I don't know how to make a 3D spring drawing? I don't know how to creat 2D views (All with dimensions) of a 3D model? I don't know how to work with render?
    Can anyone help me please? I'm using AutoCAD-2002.
    I do hope of a kind responce from you all.
    Thanks in advance.
    Naveen Kumar
    0,0,0 The Origin
    8,570
    Hi. Welcome.
    These threads and the links within them should help you get started -
    http://forums.augi.com/showthread.php?t=35447
    http://forums.augi.com/showthread.php?t=11316
    For 2d views, create Viewports in paperspace (= a layout tab) and adjust your views - 1 within each viewport. Make sure you have a co-ordinate system (UCS) in each viewport that is plan to (looking straight at) your model
    You can dimension in either modelspace or paperspace, whichever works better for you.
    2006-01
    202
    Hi,
    thanks
    Depends on what the profile is shaped like.
    Recently I have been trying to extrude profiles of architraving around windows and ornate window sills.
    I found that sometimes AutoCAD would be able to extrude a profile with an arc in it, and other times it refused even though the profile was an exact copy of one which had worked. The only difference being that I had copied it and rotated it to a different UCS.
    Alternative solutions to create a solid of these profiles was to try it in Microstation or if that is not possible then instead of an arc, draw a series of short lines instead to represent the arc if this is acceptable. Fortunately we have a routine here to do this for us!
    It can be easier to use the sweep command. Place polyline in a corner of the rectangle. Click on polyline and press enter, next you click on rectangle as path, followed by enter. No need to worry about UCS.
    2005-06
    Atlanta
    118
    OH bless you for this one - I was trying to extrude a weird shape around an oval. This worked like a charm. Thanks!
    Jules
  1. 2011: extrude along 3d path
    By dennis.moyes in forum AutoCAD 3D (2007 and above)
    Last Post: 2015-04-24, 12:14 PM
  2. Extrude to Path not working???
    By larrytech10 in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-03-29, 01:40 PM
  3. Extrude on Ellipse Path
    By lswinea in forum AutoCAD General
    Last Post: 2010-03-12, 08:55 PM
  4. AutoCAD 2006 extrude along a path - Profile and path are tangential.
    By judekw in forum AutoCAD 3D (2006 or below)
    Last Post: 2007-05-24, 07:48 PM
