Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 58
Thread: Isometric Dimension.....
    2007-06
    9
    Default Isometric Dimension.....
    How it works?
    2005-08
    Albania
    423
    Default Re: Isometric Dimension.....
    Quote Originally Posted by somared View Post
    How it works?
    The Isometric drawings are drawing with the angle 30 (grade) .
    They can dimensions with the Oblique option with an angle by Isometrics view.
    2005-06
    in the upper right corner
    3,033
    Quote Originally Posted by Arben.Allaraj View Post
    If you create your isometric drawing accurately using AutoCAD's snap, style: "Isometric" you can dimension your geometry using the "dimaligned" command. Then you can do a "dimedit" select "oblique" and change it to 30 degrees (or -30 degrees depending on your needed angle).
    See my attached example, I also changed the text style (for the dimension style) to be 30 degrees "oblique" to make it look better.
    There may be better ways to do this, but this is how I've done Isometric drawings with accurate dimensions that look good.
    Good Luck
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
    All AUGI, all the time Richard.Kent's Avatar
    2001-01
    Albuquerque, NM, USA
    622
    1 members found this post helpful.
    I have attached a drawing that I use that explains how to do iso dims and text. If you insert and explode it in a drawing you can use matchprop to adjust most of the text or dims. The drawing has iso arrows as well and are used in the dimstyles.
    HTH
    (post 100!, woot woot woot)
    All AUGI, all the time jmctamney's Avatar
    Blue Springs, MO
    658
    Quote Originally Posted by kent.elrod View Post
    HTH
    AWESOME JOB!!! I don't do a lot of iso dimensioning but when I do I always strugle with the angles. This is a great turorial!!
    (P.S. congrats on 100 posts)
    2001-01
    622
    Thanks for the nice comments.
    2007-06
    9
    Thanks a lot for those who replied......that's so good, it help me a lot on my isometric drawing.
    0,0,0 The Origin
    8,569
    You could look at ATP152 in the ATP archive - scroll down to August 2006.
    John B
    2005-06
    3,033
    HTH
    Very nice!
    I liked "isometric" arrow heads too, I never thought of that!
    You are showing what I was trying to explain (less the awesome arrow heads) and you created separate text styles too which is a nice touch.
    Thanks for sharing and congrats on 100(+) posts.
    Ted
    2001-01
    622
    I am attaching a method of isometric projection for going from orthographic views to isometric. Let me know if it helped or made matters worse.
    Of course, there is less and less need for iso drawing but it is nice to know how to do, sometimes its all that is needed rather than 3D.
    I just noticed that in the drawing I have Step 1 under the ortho views but the instructions for step 1 refer to the area labeled step 2, etc. I think it will be obvious which paragraph goes with which section.
  1. 2014: How do I fillet, chamfer, and dimension in isometric?
    By Vagulus in forum AutoCAD General
    Last Post: 2013-08-30, 04:45 PM
  2. How-to Dimension Isometric drawings
    By mjpestalitz in forum AutoCAD General
    Last Post: 2010-05-17, 02:00 AM
  3. Isometric
    By wdvaden in forum AMEP General
    Last Post: 2009-10-16, 04:17 PM
  4. Replies: 3
    Last Post: 2007-11-16, 11:56 PM
  5. Isometric Dimension
    By Merlin in forum AutoCAD General
    Last Post: 2005-12-01, 12:14 AM
