Page 6 of 6 FirstFirst ... 23456
Results 51 to 58 of 58
Thread: Isometric Dimension.....
  1. #51
    0,0,0 The Origin
    8,570
    Default Re: Isometric Dimension.....
    Quote Originally Posted by msroble33301912 View Post
    My first post on here, and I know, I HAVE to get this username changed... LOL
    Welcome to AUGI.
    This way I'm not toggling between 330 and 30 on each an every dimension every time.
    The exact reason for using styles.
  2. #52
    2013-02
    Isometric drawing is used in CAD Design. Isometric drawing is a method of designing an object in three dimensions, which you can summarize into two steps: draw the object's height lines vertically, and the width and depth lines in a 30-degree angle to an imaginary horizontal axis. When the drawing is over, it will be like you're watching the object from above at a three-quarter angle. All you need to draw an object using the isometric method is a ruler to keep the object's proportions and a protractor to measure the 30-degree angles.
    Last edited by Wanderer; 2013-02-11 at 08:12 PM. Reason: removed URL. Don't spam the forums.
  3. #53
    0,0,0 The Origin
    8,570
    Quote Originally Posted by novadesign.co.uk357071 View Post
    Since this is CAD, why on earth do you need a ruler and protractor?
    And quoting a definition does not help with the "how ..." questions.
    Welcome to AUGI.
  4. #54
    2013-03
    What about the arrowheads, are these able to be changed?
  5. #55
    2005-06
    in the upper right corner
    3,508
    Quote Originally Posted by rmccann2364018 View Post
    Welcome to AUGI!
    Not sure if this is what you are asking, but yes if you create different dimstyles for Isometric angles, you can change the arrows.
    I suspect you would need to create user-defined arrows if you want them anlgled too.
    If not, they would be just regular arrow heads.
    Is that what you mean?
    If I have a minute... I will check and post back
  6. #56
    0,0,0 The Origin
    8,570
    Look at page 1, post #4 in this thread - and welcome to AUGI.
  7. #57
    2005-06
    3,508
    Quote Originally Posted by jaberwok View Post
    Nice call John, forgot about that post.
    That should help.
  8. #58
    2014-01
    Thumbs up Re: Isometric Dimension.....
    It's great of having these practises.
    Would be good for you too.
    Get it and draw and have fun !!
  1. How-to Dimension Isometric drawings
    By mjpestalitz in forum AutoCAD General
    Last Post: 2021-06-17, 08:58 AM
  2. 2014: How do I fillet, chamfer, and dimension in isometric?
    By Vagulus in forum AutoCAD General
    Last Post: 2013-08-30, 04:45 PM
  3. Isometric
    By wdvaden in forum AMEP General
    Last Post: 2009-10-16, 04:17 PM
  4. Replies: 3
    Last Post: 2007-11-16, 11:56 PM
  5. Isometric Dimension
    By Merlin in forum AutoCAD General
    Last Post: 2005-12-01, 12:14 AM
