Results 1 to 8 of 8
Thread: Autodesk Map 2005
    2004-06
    32
    Unhappy Autodesk Map 2005
    I'm new at this, so here goes! Is it possible to import GPS waypoint data into Autodesk Map? I'm probably in the wrong forum.....Thanks in advance.
    2001-10
    Arizona
    2,337
    Default Re: Autodesk Map 2005
    What format is that data in?
    I think this is directly possible in MAP 3d
    not just MAP.
    Although you might be limited based on the export
    format of the GPS data, to use of the Survey or Field Survey
    products.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2001-03
    13,499
    Hi
    Please note I've *moved* this Topic (Thread) from the AutoCAD Customization Forum to this one as I believe it would be better served here.
    Thanks, Mike
    Forum Moderator
    2004-06
    32
    The files are .loc & .gpx?
    2004-06
    32
    I'm trying to upload a Garmin unit.
    2001-10
    Arizona
    2,337
    Not without some further processing.
    It sounds as if this is not a Survey grade
    unit so that data would lack in accuracy.
    Or there is some software that shipped with it that
    will let you create a DXF file to import into MAP.
    Be your Best,
    Michael Farrell
    100 Club JeremiahM's Avatar
    Denver, CO
    181
    You should also be able to export to a text file of some sort. With that you can Import them into Map3D directly using the Civil>> Points>> Import and Create Points command. If you are not in Map3D you could write a script to issue the point command and run your XYZ's (need to be comma delimeted).
    Jeremiah
    Jeremiah McKnelly, GISP
    www.spatialbiz.com
    Weapons of choice: Map 3D, AUD, AIMS and SQL!
    2001-05
    Austin, TX USA
    2,201
    Check out GPS2CAD & GPS2CAD-rv by AzTechSoft. I haven't ever used these programs, but it sound like they will do what you want.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
  1. Autodesk Map 3D 2005 installation
    By cynthia.biacofsky in forum AutoCAD Map 3D - General
    Last Post: 2008-08-06, 12:08 PM
  2. Autodesk University 2005
    By ssmith.54893 in forum Training
    Last Post: 2005-08-01, 08:14 PM
  3. Replies: 1
    Last Post: 2005-06-07, 02:53 AM
  4. Autodesk Map 2005
    By mickb in forum AutoCAD Map 3D - General
    Last Post: 2005-05-03, 01:48 PM
