Results 1 to 7 of 7
Thread: Non-scaling annotation symbol
    2007-06
    36
    Default Non-scaling annotation symbol
    For condo units, etc. we need an annotation that can be dropped in representing the clear floor space in front of appliances, fixtures, etc.
    We would rather it be an annotation element that is view specific. Since symbols scale with views and this element needs to represent the exact clear floor space does anyone have ideas for how to accomplish this?
    2005-07
    Somewhere in the BIM world
    3,147
    Default Re: Non-scaling annotation symbol
    Use a generic annotation with a shared parameter to achieve that.
    2003-08
    Vancouver, BC Canada
    3,419
    Why not make it symbolic lines as part of the appliance family?
    If you need it to be view specific you can add a yes/no parameter to control visibility of the lines.
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    2007-06
    36
    How is that view specific? I tried the suggestion with multiple views and when I turned it off in one, it turned off in the other view as well.
    Thanks!
    2007-06
    36
    We could place some of them as symbolic lines in the appliance family files but in some cases the code allows for variable locations of the clear space. So some families would have the clearances and some would need to be "manually" placed.
    Thanks again for the advice!
    2004-07
    Saint Paul, MN
    59
    Quote Originally Posted by Dimitri Harvalias View Post
    This is what we do for housing units but instead of yes/ no parameter
    we use a separate line category for FHA/ADA clearances, and control then in each view through view templates
    2003-08
    3,419
    Quote Originally Posted by ErichB View Post
    Thanks!
    Make sure you create the parameter as an instance parameter and you should be able to control it for each insert of the family.
    BIMblog.ca
  1. Description Key Symbol Scaling
    By rlshound in forum AutoCAD Land Desktop - General
    Last Post: 2010-01-23, 12:02 PM
  2. Annotation Scaling Performance Hit
    By philA in forum AutoCAD Annotation
    Last Post: 2008-10-13, 10:29 PM
  3. Annotation Scaling
    By Binu Mathew in forum AutoCAD General
    Last Post: 2008-08-26, 02:59 PM
  4. Symbol scaling issues
    By moseeng in forum Land Desktop - General
    Last Post: 2007-04-24, 02:13 PM
  5. Lisp for scaling multiple blocks (symbol)
    By Tolgak in forum AutoLISP
    Last Post: 2004-12-09, 07:37 PM
