Thread: Crash when dimensioning to imported DWG
    2003-08
    Vancouver, BC Canada
    3,393
    Default Crash when dimensioning to imported DWG
    I have a user who is experiencing a repeatable problem.
    When she dimensions from a Revit object to a line or other element in an imported dwg file Revit will crash.
    Anyone else experiencing this issue and have you come across any fixes?
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    2005-07
    Somewhere in the BIM world
    3,140
    Default Re: Crash when dimensioning to imported DWG
    No but i always mention not to do it. Draw a ref plane and dimension to it.
    2003-08
    3,393
    So, Daniel, if you weren't having problems what made you think of saying not to do it
    Any reason you can think of as to why this might happen?
    I'll suggest your solution in the meantime and see if that does the trick. Thanks
    BIMblog.ca
    2005-07
    3,140
    I always mention not to use DWG for anything besides drawing on top of it. Then if you unlink the DWG you dont have a series of warning. Same applies if that DWG change.
    My 2cents
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,268
    I had a problem with imported cad files crashing Revit. Make sure there are no imported bimaps. I think this problem was fixed in the latest build however.
  1. Can't Get Journal to fix crash/test crash
    By Hulston1982 in forum Revit Architecture - General
    Last Post: 2008-07-07, 08:58 PM
  2. RS 4 causes RB 9.1 to crash?
    By Kirk Bricker in forum Revit Structure - General
    Last Post: 2007-05-02, 02:36 PM
  3. STC crash!! Help
    By Shaun v Rooyen in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2005-10-23, 02:55 PM
  4. crash, bang, wallop! ( Radiosity Crash)
    By gmak in forum Revit - Rendering
    Last Post: 2004-07-16, 09:20 PM
  5. crash, bang, wallop! ( Radiosity Crash)
    By gmak in forum Revit Architecture - General
    Last Post: 2004-07-15, 04:22 PM
