Thread: A though question on alignment - station labeling
    2007-09
    10
    Smile A though question on alignment - station labeling
    Here in Israel, we are using a different labeling method for stations on alignment.
    The stations are numbered sequentially (1,2,3…or 100,101,102…etc..), no connection to the distance on the alignment.
    I tried to change styles, but it did not work.
    Any suggestion?
    Thanks.
    Active Member bruce.adams's Avatar
    2005-05
    New England
    59
    Default Re: A though question on alignment - station labeling
    Stationing is a function of distance in LDT and C3D. Question, if you are not stationing your alignment by distance what is the basis of your stationing? Where do you decide to put in the stations. I'm assuming at some sort of geometry point. After asking that, I guess you could add surface points along your alignment and label them what ever you want.
    Bruce Adams
    AEC Civil QA
    Autodesk
    2007-09
    10
    Thank you.
    If I may, I am looking for a sample of FLT file (Softdesk for break lines). Do you have it or knows where to get it ?
  1. labeling northing & easting on an alignment
    By Maverick91 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2012-03-29, 04:02 PM
  2. Alignment Station label that is perpendicular to alignment
    By corbittshoffner in forum AutoCAD Civil 3D - Alignments
    Last Post: 2010-05-20, 10:43 PM
  3. Alignment Labeling - C/L Grade and Distance
    By kevin.jackman in forum AutoCAD Civil 3D - Alignments
    Last Post: 2010-02-12, 02:22 PM
  4. Alignment / Pipe Labeling
    By avn in forum AutoCAD Civil 3D - General
    Last Post: 2007-05-16, 07:34 PM
  5. Smart Station Labeling
    By caddjockey2000 in forum AutoCAD Land Desktop - Wish List (Closed)
    Last Post: 2004-11-01, 03:27 PM
