Thread: Ability to customize elevation tags
    Wish List Administration
    2007-08
    603
    Default Ability to customize elevation tags
    Summary: Self-explanatory.
    Description: Ability to customize elevation tags.
    How Used: Ability to customize elevation tags.
    Feature Affinity: Annotation tools
    Submitted By: Bret Thompson on September 13, 2007
    Pittsburgh, PA USA
    1,906
    Exclamation Re: Ability to customize elevation tags
    This is a critical need in several different ways. Elevation tags need to work in same manner as section tags, in that you need to be able to have them show in parent views by default, and then turn on intersecting views if you want. Also, elevation tags need to take on the minimum scale of the view they are placed in as the minimum scale they will be seen at, instead of always taking 1:400 as the minimum scale.
    2005-07
    3,250
    Default Re: Ability to customize elevation tags
    Quote Originally Posted by swomack View Post
    I don't think this statement is correct. Sections don't work that way, not even detail sections. Only callouts have the property you are referring to and can display as a section cut in intersecting views. BUT, they have to be placed as callouts to work that way.
    Pittsburgh, PA USA
    1,906
    Wink Re: Ability to customize elevation tags
    David,
    True, I did not clearly differentiate between sections and callouts. Sections do not show-up every where, in every view the way elevations do. Even if elevation tags were made to function like section marks it would be a huge improvement. All of these tags that create views should function in the same manner.
    2011-08
    4,581
    This wish has been reported as granted and already in the software.
  1. Ability to rotate annotation tags
    Last Post: 2014-05-16, 04:01 PM
  2. add ability to set angle of elevation and section tags
    Last Post: 2013-09-13, 03:16 PM
  3. how do I customize the Elevation Tag
    By Jason Shirriff in forum Revit Architecture - Families
    Last Post: 2012-04-13, 01:39 PM
  4. Ramps should have the ability to be annotated using slope symbols and elevation markers
    Last Post: 2012-01-13, 05:49 PM
  5. Replies: 2
    Last Post: 2005-06-17, 04:18 PM
