Results 1 to 8 of 8
Thread: Material Problems
    2007-09
    6
    Default Material Problems
    Does anyone know what causes this (see attachment)? It looks as if the material, only in these corners of the walls, applys itself in relation to the face part of the mesh. A map scaler modifier was used for the brick. The wall is part of a building that was brought into VIZ from AutoCAD Architecture. I appreciate any suggestions.
    Steve
    Administrator Steve_Bennett's Avatar
    2004-05
    Somewhere near there
    4,627
    Default Re: Material Problems
    Have you tried applying a UVW map to the face of that object?
    Steve Bennett / CAD Manager
    HMC Architects / Adventures in BIM
    2007-09
    6
    I've applied a UVW map and a Mapscaler modifier and I'm left with the same result.
    2004-05
    4,627
    What settings did you use on the Map Scaler and UVW map? Screen shots will suffice.
    Materials have lots of settings so the more detail you can provide the more we can help.
    Also, are you using mr materials or standard VIZ materials?
    I could stop if I wanted to dellis's Avatar
    2003-12
    Windsor, Ontario, Canada
    379
    You might want to check for coplanar surfaces as well!
    Design Visualization Moderator stusic's Avatar
    2004-10
    N32° 32' 19.08", W-84° 52' 59.03"
    1,280
    Quote Originally Posted by dellis View Post
    Yeah, that's what it looks like to me.
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Administrator, Heatcraft RPD
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    2007-09
    6
    Yep, coplanar surfaces was the culprit.
    Thanks
    2004-10
    1,280
    Thanks for reporting back, Ironwood, it really helps other users who run into the same problem.
    Phillip Bradshaw
  1. Material Takeoff Problems....Help
    By eric.110455 in forum Revit Architecture - General
    Last Post: 2011-01-19, 08:12 PM
  2. Material Mapping/RPC Rendering Problems
    By mmulloy in forum Revit - Rendering
    Last Post: 2010-03-18, 02:58 PM
  3. Material Editor Problems
    By herreraenrique in forum 3ds Max - General
    Last Post: 2009-12-29, 09:33 PM
  4. sketchup to 3ds Max Design material problems
    By mbutler.136569 in forum 3ds Max - General
    Last Post: 2008-09-04, 04:21 AM
  5. Material Problems In Families
    By jyoungner in forum Revit Architecture - General
    Last Post: 2008-01-09, 05:52 PM
