Thread: Light Fixture, HVAC, Ceiling line weights?
    100 Club m_cahoon14336's Avatar
    2004-02
    Jonesboro, AR
    186
    Default Light Fixture, HVAC, Ceiling line weights?
    I have a 2x2 suspended ceiling with standard revit library lay-in light fixtures, hvac diffusers, etc. I am trying to make the fixtures and diffusers print darker. I have changed the line weights via object styles, but this does not seam to change it for me. How should I go about making this change?
    Thanks
    Colquhoun
    Wrong is wrong even if everyone is doing it; right is right even if no one is doing it. - St. Augustine
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Light Fixture, HVAC, Ceiling line weights?
    That should do it, open the families and see what object style the symbol lines are on. Then make sure that is set to the lineweight you want
    Scott D. Brown, AIA
    BECK
    2004-02
    Jonesboro, AR
    186
    Thanks Scott. It was a dumb error on my part. It works as it should now.
    Colquhoun
  1. 2013: Ceiling Based Recessed Light Fixture Doesn't Work
    By bwilliams133 in forum Revit Architecture - Families
    Last Post: 2014-01-14, 12:01 PM
  2. Replies: 4
    Last Post: 2011-09-29, 02:15 AM
  3. 3D light fixture family/ceiling issue...
    By mstuver876126 in forum Revit MEP - General
    Last Post: 2008-09-23, 05:17 PM
  4. Sloped Ceiling and Light Fixture
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2008-01-11, 07:12 PM
  5. ACT Ceiling & Light Fixture Issues
    By rookwood in forum Revit - Rendering
    Last Post: 2005-07-16, 01:18 PM
