Thread: wall tags....what are they referenecing?
    2006-04
    418
    Default wall tags....what are they referenecing?
    I changed the "Mark" in the wall properties to a number. I placed a wall tag in my drawings and all i got was a "?". I gave the tag a number manualy. Then the same number came up in the wall tag on a seperate identical wall type (so, it works). There are just a few wall types in the job, so its no big deal. But on a larger project i'm going to want to establish the number in the wall properties. I think? What is the tag refernecing? I thought it was "mark" in wall properties.
    All AUGI, all the time Justin Marchiel's Avatar
    2004-07
    Penticton, B.C., Canada
    954
    Default Re: wall tags....what are they referenecing?
    by default it references the Type Mark, not just the mark
    Vancouver, BC Canada
    3,753
    If you open the tag family in the family editor (select it and click Edit Family on the options bar)you can check to see which parameter it is reporting.
    In the family editor select the label and then click the Select Parameter... button on the options bar.
  1. 2013: Revit Architecture - Wall Tags and Wall Legend (sketch of wall)
    By ROBP-RDS in forum Revit Architecture - General
    Last Post: 2013-07-02, 05:52 PM
  2. 2011: Wall Tags
    By Chuckyd67 in forum ACA General
    Last Post: 2011-12-21, 03:27 PM
  3. Wall Tags
    By Tungsten in forum Revit Architecture - General
    Last Post: 2008-06-18, 09:23 AM
  4. Wall Tags
    By rhayes.99001 in forum ACA General
    Last Post: 2007-10-16, 04:52 AM
  5. Wall Tags
    By captainbunsaver in forum Revit Architecture - General
    Last Post: 2006-02-20, 05:19 PM
