can anyone tell me how to make this printer print out Autocad 2000 drawings?And if i get an answer where can i find it? (new to this)
regards
regards
Hi
Please note I've *moved* this Topic (Thread) from the Operating Systems Win XP Forum to this one as I believe it would be better served here.
Thanks, Mike
Forum Moderator
Hi
Is your AutoCAD installation up to date with regards Service Pack 2 + AutoCAD 2000 Plotting Update Patch -
AutoCAD 2000 Updates & Service Packs
First install the printer as a Windows System printer (you can then print direct to this device from within AutoCAD if you so wish, but personally I would recommend doing the following so you have greater control from within AutoCAD).
Create an AutoCAD .PC3 Plotter -
Find the "Add-A-Plotter wizard" (should find a copy in the AutoCAD Plotters directory/folder under your AutoCAD installation) -> Add Plotter - Begin (window), you now have a choice to either go with an AutoCAD Heidi Driver or a Windows System Printer Driver, you may want to try both, then decide which one works best for you.
The following Technical Documents on the Autodesk web site under the Knowledge Base should hopefully offer more help/guidance -
ID: TS31567 - Configure plotter/printer
ID: TS17735 - Selections on Begin page of Add-A-Plotter wizard explained
ID: TS20135 - Create plotter configuration files (PC3)
ID: TS45174 - Information about AutoCAD 2000 Plotting Update Patch
ID: TS65465 - Location of drivers for HP printers and plotters
ID: TS47627 - Error when plotting to network with HP Optimized driver
The following area on the HP web site -
HP PSC 1210 All-in-One
Have a good one, Mike
Sounds like you don't have a AutoCAD and you need a "DWG viewer".
AutoDesk sells DWG viewers![]()
But there are "Free DWG Viewers" ... go to yahoo.com and type in "Free DWG Viewers".
http://search.yahoo.com/search?p=Fre...t&cop=mss&tab=
Then plot from there .....![]()
HTH
R.
