Ok guys, I've searched all over for this and no one seems to be able to give a clear answer on this.
How do you LINK, a dwg file into a new mass family?
What I am trying to do is LINK, not import, LINK, a dwg file exported from SketchUp into a mass family. However, the "link" option is grayed out when you import into a mass family.
Here's what I'm after in the end.
1. Create a massing model in SketchUp as a preliminary design study.
2. Import that model into a Revit mass and use it to create walls, floors, roofs, etc.
3. Then, if something changes in this early design phase, I change the sketchup model.
4. Then, I update the dwg that's linked into the massing model, and since my walls, floors, and roofs, will readjust themselves to the re-shaped mass, I don't have to repeat the Wall by Face, et al commands.
This is completely possible according to the RAC 2008 help file. I quote:
"You can use SketchUp to create large-scale massing studies, and then use Revit Architecture to associate host elements (walls, roofs, and so on) to the mass faces. In SketchUp, be careful of the origin (with regard to the Origin in the Revit Family Editor), so that subsequent revisions in SketchUp can be predictably maintained.
In order for Revit Architecture to understand the exported geometry as a mass object, link the file to a Mass Family component. Revit Architecture then treats the geometry as a mass, allowing the faces of the mass component to be selected and associated to Revit host elements. Furthermore, the relationship between imported mass geometry is maintained if the SketchUp file is modified, exported, and reloaded in the Revit project."
Later in this same help file, Autodesk has even created a tutorial for this where they once again tell you to LINK the dwg file into the family:
"In SketchUp, create the massing study, and export it to a DWG file.
In Revit Architecture, click File menuNewFamily. Select Mass.rft.
For details, see Creating a Mass Family Outside of a Project.
Link the exported DWG file into the family.
For details, see Importing or Linking CAD Files Using the Import/Link Command.
Save the mass family.
Load the mass family into the Revit project and place the component.
For details, see Placing a Mass Instance from a Mass Family.
To convert the faces of the mass component, use the Wall by Face, Roof by Face, and Curtain Wall by Face commands."
The problem is, the "link" option is grayed out.
Has anyone cracked this issue? If so, please help us all out.
Thanks.
