Thread: Bind xref
    2007-08
    Default Bind xref
    Any idea how to bind all xrefs in 1 command.
    Serge
    Houston
    7,542
    Default Re: Bind xref
    Command: -XREF
    Enter an option [?/Bind/Detach/Path/Unload/Reload/Overlay/Attach] <Attach>: _B
    Enter xref name(s) to bind: *
    Command:
    AUGI Addict tedg's Avatar
    2005-06
    in the upper right corner
    2,318
    Command: -XREF
    Command:
    Also, if you want the "insert" option (versus "bind" option) you'll need to set the "bindtype" variable to "1"
    I didn't test it, but I would assume you would add to your routine:
    (setvar "bindtype" 1)
    Update.. I tested this one:
    ;;;BIND-INSERT ALL LOADED XREFS
    (defun c:bxr ()
    (SETVAR "BINDTYPE" 1)
    (COMMAND "-xref" "reload" "*" "");;reload all xrefs
    (COMMAND "-xref" "bind" "*" "")
    I tried this and it worked ok, but it tripped up if you have xrefs unloaded.
    So I added the reload xrefs command too.
    (which may be a problem if you didn't want that one in the file)
    Ted
    ____________________________________________________________________________________
    AutoCAD 2012 - REVIT Structure 2012 - MicroStation V8i - Windows 7 Professional - (dabble with Inventor 2012)
  1. Bind an xref with VLISP
    By msretenovic in forum AutoLISP
    Last Post: 2011-08-24, 07:44 PM
  2. Bind Xref's in C#
    By joelkarr in forum Dot Net API
    Last Post: 2009-01-29, 08:46 PM
  3. Bind a vault xref
    By gandocadguy in forum Vault - General
    Last Post: 2008-11-13, 02:05 PM
  4. Unable to Bind Xref's / Some Xref's no longer there
    By cwjean76 in forum AutoCAD General
    Last Post: 2006-12-22, 04:00 PM
  5. Xref Bind
    By rflores.73491 in forum AutoCAD General
    Last Post: 2005-01-05, 11:11 PM
