Thread: How to write new menu file or update the existing menu in AutoCAD 2006
    8
    Unhappy How to write new menu file or update the existing menu in AutoCAD 2006
    AS there is no *.mnu or *.mns file in AutoCAD 2006, so how shall I update the existing menu or write new menu file in AutoCAD 2006.
    Can anyone please suggest me?
    Earth
    9,805
    Exclamation Re: How to write new menu file or update the existing menu in AutoCAD 2006
    1. Use the CUI command. Create your own partial menu, don't edit the stock OOTB menus.
    2. You can also still create an MNU file the "old-fashioned" way, then load it. (It will be converted into a CUI file). You can maintain this MNU file and just load it each time you want to make a change. This is what we do with our company menu. Much easier to make edits in Notepad, than in the CUI.
    3. If you have a CUI file that you want to convert back to a MNU file, see http://rkmcswain.blogspot.com/2007/0...ui-to-mnu.html
    R.K. McSwain | CAD Panacea |
  1. AutoCAD Map 2006 Window menu
    By sherflor in forum AutoCAD CUI Menus
    Last Post: 2008-08-11, 06:19 PM
  2. AutoCAD 2006 menu issue
    By Kioti in forum AutoCAD CUI Menus
    Last Post: 2008-07-07, 04:29 PM
  3. Setting up an Image Tile Menu in AutoCAD LT 2006
    By greg_powell.136628 in forum AutoCAD CUI Menus
    Last Post: 2007-04-09, 03:11 PM
  4. AutoCAD 2006 and menu files
    By fletch97 in forum AutoCAD CUI Menus
    Last Post: 2006-03-15, 10:46 PM
  5. Reloading Express Tools menu in AutoCAD 2006
    By Haden in forum AutoCAD General
    Last Post: 2006-01-27, 05:15 PM
