Results 1 to 8 of 8
Thread: Greyed-Out Level Heads
    2003-09
    California
    400
    Default Greyed-Out Level Heads
    I have a level that listed as Level 2; however, I can't seem to select it or delete it. It's not listed in the Browser window. I can't seem to find any reference to it.
    Also, I have a Floor Plan level that is grayed-out, how do I make this black?
    I know I'm missing something simple, so what is it?
    Thanks for your help.
    2003-05
    5,153
    Default Re: Greyed-Out Level Heads
    From a similar topic ....
    Quote Originally Posted by Steve_Stafford
    If you are not too far along in the project, a copy to clipboard of the entire model from a 3d view and paste into a new project should eliminate it. But I doubt you'd want to go there if you've got views and sheets set up already.
    Talk with support.
    2003-09
    California
    400
    beegee,
    Thanks for you help. I guess I'll be contacting technical support.....
    2001-12
    Irvine, CA
    7,567
    Yup...support can fix this usually, and other than what I described it's the "only" way.
    If you can determine what you might have done to accomplish this feat it will be a big help to us all. They thought they fixed this issue, but it appears that it is still possible in some instances. Is it possible that this project is an upgrade child?
    2003-09
    California
    400
    No it isn't upgraded. It was started in 6.1. However, maybe the problem occurred when I transfered the project standards from a project that was upgraded from 5.0 to 6.1. Maybe this had an affect on it......
    Moderator JamesVan's Avatar
    2016-01
    New York, NY
    625
    Do you have groups on multiple levels? I think this problem has to do with editing either a group or an in-place family on a different level than it was originally created. We've encountered the same problem.
    2004-05
    104
    I've just encountered this problem.
    In this instance the level is a duplicate of an existing one, and it has somehow reduced its height by 150mm
    Even more annoying - when I try to select all from a 3d view to try the fix previously suggested, I get a 'can't copy selection error'
    I don't have multiple groups on levels etc.
    Only things I recently did was add some planting, add a scope box, right clicked on some crop boxes and elevations to hide them, duplicated some elevations, and added a sheet
    2004-05
    104
    Following a bit more reading regarding copying groups from one project to another, it seems that if you do this, then levels can be copied and imported too.
    Going through my backups, it appears that I did copy a fence component from another project, and it was the level from this project that was copied across too.
    I have recently reduced the 'number of backup saves' option form 20 to 5. But I think it will be returning to 20 from now on!
  1. 2015: 1st level objects greyed out and visible on 2nd level floor plan
    By booyahhhnia342307 in forum Revit Architecture - General
    Last Post: 2015-06-11, 03:14 PM
  2. Question:Change a Components Level when greyed out
    By jan.76519 in forum Revit Architecture - General
    Last Post: 2009-08-31, 01:23 PM
  3. Level Heads
    By brd in forum Revit Architecture - General
    Last Post: 2006-08-10, 03:42 PM
  4. Level Heads
    By kdsarch in forum Revit Architecture - General
    Last Post: 2005-07-08, 01:13 PM
  5. Level Heads
    By gregcashen in forum Revit Architecture - General
    Last Post: 2003-05-14, 12:52 PM
