Thread: Replace Z Value with Current Elevation?
    2006-09
    255
    Default Replace Z Value with Current Elevation?
    Hi
    There's an option in the Options dialog to 'Replace Z Value with Current
    Elevation'. But there appears to be no Variable to change it (from the Help).
    Can this be done at the command line or programmatically?
    Cheers
    Dave F.
    2001-08
    On the other side of the pond, where they speak real English!
    40
    Default Re: Replace Z Value with Current Elevation?
    If you use the OSNAPZ system variable at the command line it does much the same thing. It's just a 0 or 1 setting - can't remember off the top of my head which way round it is to ignore the Z value, but hey it won't take long to figure out!!
    Regards
    Spike
    2006-09
    255
    Quote Originally Posted by philpiper View Post
    Regards
    Spike
    Cheers Spike - That's precisely what I want.
    Damn the help file (once again) for not noting it.
    2004-08
    Iron Station, NC
    3,198
    Quote Originally Posted by Dave F. View Post
    Hi
    Cheers
    Dave F.
    are you refering to the ability to change the dialog option or to change the current elevation?
    if you want to change the current elevation, try ELEV, otherwise OSNAPZ is what you are looking for.
  1. 2014: Spot elevation tag: current level is not current?
    By Pavlin in forum Revit Architecture - General
    Last Post: 2014-07-08, 10:21 AM
  2. Add replace function "Replace from Clipboard".
    Last Post: 2013-02-01, 08:03 AM
  3. Set "add points" to current elevation
    By CADDaddy in forum Revit Architecture - General
    Last Post: 2011-07-27, 11:05 PM
  4. Change current elevation in property palette
    Last Post: 2006-09-26, 01:50 PM
