Thread: Weird Material Tag Behavior
    2006-04
    Baltimore, MD
    379
    Default Weird Material Tag Behavior
    I'm using material tags on elevations in a DD set. I've used this tag many times before with no problems. However, now when I tag a material a ? appears until I move the leader end around, then the material description shows up. <Edit: Moving any part of the tag makes the description show up - even nudging the entire tag over a bit.> I tried it with both a custom tag and the OOTB tag and had the same problem. Then I started a new project and the tag worked fine. Any ideas?
    Member Bob Eardley's Avatar
    2004-10
    10
    Default Re: Weird Material Tag Behavior
    does this only happen in that one project?
    2006-04
    Baltimore, MD
    379
    Yeah, it's only in this one project, and I've further discovered that it's only in specific views. It seems to work in partial less complex elevation views, but not in the full elevations. I'm thinking it has something to do with the complexity of the views.
    2008-10
    3
    sorry to drag this out of the dim past
    this was the closest that came up in a search
    yes that is happening to me too
    however quickly checking back to Revit while reading the replies, confirms that there seems to be a dependency on the Model View type ( coarse/med/fine )
    I hve yet to come up with a predictable schema, but you have to set the view type to how it will finally be printed off at before placing the tag. However the manual says to have the text in the description tab of the material preset as a time saver - however various behaviours don't entirely line up with that advice
    has anyone sorted this out? so that we don't have to do double and triple takes all the time?
    [small] Revit 2009 - XP Pro under Parallels Virualization on iMAC [/size]
  1. Host Sweeps material not showing up on a material schedule
    By wadeshuey in forum Revit Architecture - General
    Last Post: 2011-09-23, 07:13 PM
  2. Weird dynamic block behavior
    By raudelh in forum Dynamic Blocks - Technical
    Last Post: 2008-07-08, 02:04 PM
  3. Interesting material fill paint bucket behavior
    Last Post: 2007-11-19, 09:59 PM
  4. Weird Material Problem
    By Tyveka in forum Revit Architecture - General
    Last Post: 2007-01-04, 05:30 PM
  5. Weird Mouse Behavior...
    By gregcashen in forum Revit - Hardware & Operating Systems
    Last Post: 2003-05-29, 10:16 PM
