Thread: Xrefed layer states not displaying in layer state manager
    Active Member ewhite's Avatar
    2003-08
    Minnesota
    83
    Exclamation Xrefed layer states not displaying in layer state manager
    Ok, so I have 2 .dwt files that each pertain to different types of bases, each has different layer states defined in them. I create 2 new base drawings using the templates and the layer states are created as they should be.
    Then, I create a new drawing for a sheet, and xref the two base drawings into them. I then go into the layer state manager and make sure the "Don't list layer states in Xrefs" radio button is unchecked. But only one of the two xrefed drawing's layer states display! What gives?
    The layer states in both base drawings all have unique names, so there shouldn't be an issue there. And if I detach the xref with the working layer states, and reattach the other, it still displays nothing.
    Has anyone ever run into this, any suggestions
    Eric White
    2003-08
    Minnesota
    83
    Default Re: Xrefed layer states not displaying in layer state manager
    So, I tried to delete and recreate the layer states. And tried exporting them and reimporting them. That did not work.
    If i import the states into the base with the working layer states they do show up in the xrefed layer state list.
    Any help with this issue would be greatly appreciated.
    Eric White
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Can you attach some screen shots?
    2003-08
    Minnesota
    83
    I doubt screen shots will help you but I can attach the drawings that contain the offending states.
    both of these drawings have working layer states. But when you xref them into another drawing, thats when the problem occors.
    Eric White
  1. Layer States vs. Layer Manager (2004-2009 issue)
    By beardking in forum AutoCAD General
    Last Post: 2011-07-21, 02:14 PM
  2. Replies: 0
    Last Post: 2011-03-15, 05:44 PM
  3. 2008 LT - XREFed Layer States Disappear
    By tl.140546 in forum AutoCAD LT - General
    Last Post: 2008-05-08, 03:40 PM
  4. Layer State Manager and layer states in Modelspace
    By mike.122149 in forum AutoCAD General
    Last Post: 2006-11-01, 03:41 AM
  5. Replies: 1
    Last Post: 2006-04-03, 10:01 PM
