When we create corridors for some reason every place an assembly is ran it places ticks from the assembly connection points on the corridor. Does anyone know what layer these are created on?
Hi Jennifer,
If you check your Corridor Code Style (found under General - Code Set Styles), you will find that the Point Styles are turned on using a defined point style. Set these to _No Marker to turn the little buggers off.
