Results 1 to 8 of 8
Thread: Reduce CAD file size before linking
    I could stop if I wanted to Chirag Mistry's Avatar
    2004-06
    Atlanta
    254
    Default Reduce CAD file size before linking
    I need to link furniture CAD files from my consultants in the revit file. These files are huge (approx 10MB each floor). I have exploded all the blocks, purged, audited, saved the file to a lower version of CAD, but nothing seems to help. I keep getting the following error (ARX_ERROR: eNotThatKindOfClass) I am assuming the consultants are using a third party software that's generating this. Any tips on how best to proceed with large CAD files.
    Thanks
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Default Re: Reduce CAD file size before linking
    Try selecting everything copy, create a new project and paste in there. If that doens't work your not likely to fix the problem.
    2003-09
    1,907
    Chirag - are you running ra2008? As you have AutoCAD is it also 2007/2008 and the drawing file comes up ok? Have you tried dwf or dxf? I know we're all guessing here, but perhaps these latter will remove the ARX issue (dwf or dxf). If the dxf works, you could dxfout then create a new acad dwg and dxfin. Probably would shrink the file and perhaps remove the arx issue.
    2005-07
    Somewhere in the BIM world
    3,792
    It might have been build with ADT, like Elmo mention, copy/paste to another project. Purge and audit. Then do it again if necessary
    2003-03
    Reno, Nv.
    277
    After doing all the explode and purge, rather than saving to a new file, have you tried wblock to a new file? I find often that wblock is the only thing that will "clean" out left over stuff.
    2004-06
    144
    FYI: exploding blocks typically makes a file larger in AUtoCAD
    2005-07
    3,250
    Easiest and best way is to wblock your stuff to a new file. That gets rid of any ADT relics.
    2005-02
    St Louis, MO and Tirunelveli, India
    130
    If you have ADT, the best way to make the file clean is to use the Export to AutoCAD command (available in the File menu of ADT)
    hth
  1. Methods / ways to reduce DWG file size
    By don.gryder in forum AutoCAD General
    Last Post: 2013-03-14, 02:15 PM
  2. 2011: How to reduce file size in AutoCAD
    By shanower_buet in forum AutoCAD General
    Last Post: 2013-03-14, 01:33 PM
  3. How can I reduce the size/polycount of my file?
    By comical_wenger in forum 3ds Max - General
    Last Post: 2010-10-19, 03:50 PM
  4. How to reduce file size in AutoCAD
    By shanower_buet in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-08-07, 07:58 PM
  5. Reduce the File size...
    By Cyril Verley in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-06-28, 09:53 PM
