cadman_meg
I understand the concepts of dynamic blocks but have yet to try and use them. This being that dynamic blocks seem more as an advantage to architectural, mechanical, etc... disciplines rather than civil which is the field I work within.
Anyhow, I found an idea that I thought would be a good start to checking out dynamic blocks, but being of limited knowledge, I am not sure where to start. My idea is quite simple. What I am after is creating a dynamic block with a dwt whereas when a new project is started, the end user would select which engineering seal to apply. So if I had one block that could reference lets say 6 engineers stamps and all the user had to do was select the project engineer and bam, that would be the block displayed. Searching and reading around through here, is seems as though the lookup function might apply to this, but I am not sure. Also, would I need multiple blocks or would it be just one block where the variable was the engineers name and the date (minus the year)?
So I was hoping some of you could tel lme where to start and how to go about this as I am wrapping up the just of this template and would like to incorporate this idea if possible. Would be much appreciated. Thanks much.
