Thread: ACAD/LDD tables
    2007-02
    6
    Default ACAD/LDD tables
    is there a way to "import" an excel into ACAD table? such as i have a table setup with the company standards i.e. linetype, lineweight, text style, and text height. but i have data given to me in an excel spreadsheet with formulas and data that need to be shown on a drawing the upper management do not like me to just insert the excel file, so any help with the ACAD tables and bringing the data from excel word be greatly appreciated
    Earth
    9,805
    Exclamation Re: ACAD/LDD tables
    Open Excel, copy the range to the clipboard, switch to AutoCAD, run the PASTESPEC command, then select "AutoCAD entities".
    If you are using 2008, you can use "Data Links" to create a table in the drawing that is linked to the Excel data.
    R.K. McSwain | CAD Panacea |
  1. Exploding Tables (Also for Vanilla ACAD)
    Last Post: 2014-04-29, 10:05 PM
  2. 2012: Liinking two or more ACAD Tables to one another
    By Darren Allen in forum AutoCAD Tables
    Last Post: 2012-10-12, 11:58 AM
  3. Create a .bat with acad.exe, a PostGIS connection and load 3 tables
    By agmartin776513 in forum AutoCAD Map 3D - General
    Last Post: 2012-09-25, 01:39 PM
  4. Replies: 4
    Last Post: 2012-09-06, 03:57 PM
  5. Row height in Acad tables
    By MikeJarosz in forum VBA/COM Interop
    Last Post: 2007-02-15, 03:50 PM
